Car will not turn over
160,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
JOSEPH BARRECA
  • 11 POSTS
Car will not start cranks for a second and makes a loud metal to metal sound like something is rubbing. could it be a starter or something worse?
Mar 27, 2018 at 1:51 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I think you should look for a cracked starter housing or loose starter bolts. also, check if the flex-plate is cracked or the teeth missing/worn down where the starter is located right now.
Mar 27, 2018 at 3:31 AM
JOSEPH BARRECA
  • 11 POSTS
The car is parked away from home had to leave it parked could not not get it to start. i did not mention before, it stalled out when I was driving then would not start back up. It makes a noise like rubbing metal for like a second then silent each time I would turn the key.
Mar 27, 2018 at 7:44 AM
JOSEPH BARRECA
  • 11 POSTS
And the head lights and dash lights went dim when trying to start also.
Mar 27, 2018 at 7:49 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I am starting to wonder then if the engine locked up.
Did the engine begin smoking and/or did the coolant temperature rise to too hot or any warning lights come on right before the engine stalled?
You should check the engine oil level and the coolant level, not as a fix per se but to see if either is really low and may be the cause that the engine did lockup.
Mar 27, 2018 at 8:32 AM
JOSEPH BARRECA
  • 11 POSTS
I did see a little bit of smoke not a lot at all. no lights and I just did a oil change and topped of coolant.
Mar 27, 2018 at 10:15 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
More the reason to check the oil level and coolant level. Maybe the oil leaked out for some reason, etc.
Mar 27, 2018 at 12:23 PM
JOSEPH BARRECA
  • 11 POSTS
I had checked the oil level the day prior and it was at the full line.
Mar 27, 2018 at 12:30 PM
JOSEPH BARRECA
  • 11 POSTS
I park on a concrete driveway and there also was not any drips or signs of leaks of any kind on the ground.
Mar 27, 2018 at 12:31 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
When you get back to the car, see if you can turn the engine over by hand to see if it is locked up or not.
Mar 27, 2018 at 1:02 PM
JOSEPH BARRECA
  • 11 POSTS
How do I go about that?
Mar 28, 2018 at 2:32 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Either of two ways, by using a six point socket on the front crankshaft bolt, if there is one or by removing the transmission flex-plate shield (cover) and using a flywheel turner tool.
Here is a photo showing how that tool is used to try to turn the flex-plate:
http://www.classiccarsandtools.com/tag/harbor-freight-tools/
Mar 28, 2018 at 3:42 AM
