Engine does not crank?
101,000 MILES • 2.5L • 6 CYL • AUTOMATIC
PURPLEBUTTERFLY613
Car won't turn over. Battery is a few weeks old. 1/2 tank of gas.
Aug 30, 2023 at 8:36 PM
  • 55,845 POSTS
It sounds like the starter has gone bad but to be sure try to crank it over in neutral this will test the gear range sensor. We need to test if the starter trigger wire is getting power to confirm the bad starter.
This guide can help:
We should check the fuses as well. This guide will help with that and show you how the system works and which fuses to test:
Here is how to change the starter out in case there is power at the trigger wire. Check out the images (below). Please let us know how it goes.
Aug 31, 2023 at 8:17 AM
PURPLEBUTTERFLY613
Okay. Thanks. It's my son's car. He just installed a new battery within the past month. Today he tried to start it and the dashboard lights sort of flickered and it didn't turn over. He hasn't tested the starter.. he's 22.. still learning about cars.
Sep 1, 2023 at 6:06 AM
  • 55,845 POSTS
So, it looks like the engine is cranking over but not starting. Please start a new thread.
Sep 2, 2023 at 3:37 AM
