Will not turn over
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
REGGIES17
True the ignition it cranks and cranks but won't catch then cuts out. Sounds like a exhale. Brand new battery. I don't think it could be electrical everything is working.
Dec 17, 2018 at 5:01 AM
  • 110,248 POSTS
It could be a few different things. For an engine to run, it needs fuel, ignition spark, compression, correct timing, and air. Take any of them away and it won't run.
First, I want you to read through this link. It discusses the most common reasons for a crank no start condition.
Let me know if anything there is helpful, what you find, or if you have other questions.
Dec 18, 2018 at 10:52 AM
