Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Charger
Engine
Symptoms
Will not shut off
Engine will not turn off?
2011 DODGE CHARGER
162,000 MILES
BETH843
MEMBER
Dash says vehicle not in park. I don't know what is going on, but i need to turn the engine off. Its been running for two hours now.
Mar 26, 2019 at 9:46 AM
Experienced Mechanic
Good morning,
The most common issue for this is the auto shutdown relay. When it does not open after turning off the key, the engine will not turn off.
I attached the wiring diagram and the location of the relay for you.
Images (Click to enlarge)
Nov 26, 2020 at 9:45 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
