car wont styay running. dies off.
2009 DODGE CARAVAN
150,000 MILES • 3.6L • 6 CYL • RWD • AUTOMATIC
JEWELCARVALHO
  • 8 POSTS
Tried all your suggestions, still same. Comp.new programmed. Fuel pressure ok. Crank shaft n cam censors, new ok.starts with gas when poured into injector. Engine starts then dies, no fuel entering injectors.
Jul 19, 2014 at 4:32 AM
HMAC300
  • 48,601 POSTS
try resetting your anti theft if no manual look nline
Jul 19, 2014 at 4:49 AM
JEWELCARVALHO
  • 8 POSTS
Security code for the key was reset. But still the same.
Jul 19, 2014 at 5:03 AM
HMAC300
  • 48,601 POSTS
fuel pressure must be 58 psi +-5 if anywhere below that it's not good.check fuse M19 at tpim and asd relay may be shutting down engine and check grounds at tpim module and near battery. then have a pro scan to see if tpim module is anygood. an autoparts scanner won't scan that.
Jul 19, 2014 at 5:12 AM
