car wont stay running! help 1990 geo storm gsi
190,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ANTHONY_30
My car wont stay running unless I prime it. I have changed the fuel pump, fuel filter, fuel module, and the ignition coil. Any ideas on what else could be causing the problem?
Jun 16, 2015 at 8:53 AM
  • 110,248 POSTS
Have you confirmed that the fuel pressure is within spec? It sounds like it is weak which may be the result of a bad pressure regulator.
Jun 16, 2015 at 12:39 PM
ANTHONY_30
No we haven't checked the pressure but we also replaced the regulator.
Jun 17, 2015 at 10:45 AM
  • 110,248 POSTS
I would check it. I have seen many times that the pump produces enough pressure to keep the engine going once started but can't produce enough to start the engine.
Jun 18, 2015 at 12:03 PM
