Shuts off while driving and idling and not starting, check engine light on
160,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
LEARNERNOW
Car would cut off while driving and when idling and would start back up after an hour or so. Then it got to where it took hours to start. Diagnosis said change main relay so i purchased that. It still wouldn't start. Several mechanics said it wasn't getting fuel. I didn't hear the fuel pump running so i've been trying to locate the fuel pump relay with no luck. Located the fuse but no relay. The car's information display says 'gearbox malfunction' and the check engine light is on.
Aug 23, 2021 at 1:00 AM
BORIS K
  • 836 POSTS
The best way forward would be to a have CAN scan done to establish what fault codes are stored. Once that is done please post the fault code list with us for more in-depth diagnosis.
Here's how to carry out a scan:
Please let us know how you get along.
Cheers, Boris
Aug 23, 2021 at 7:40 PM
