car will not start when warmed up
105,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
CAMUMA34
the car starts fine when its cool, but when you drive for thirty minutes and try to start again, it cranks but wont start. Check engine light on p0183 fuel temp sensor and p0462 fuel level sensor, I already replace the fuel pump and still the same.
I replace fuel pump relay and cam and crank sensor no luck at all.
please help!
Aug 16, 2016 at 1:05 AM
KHLOW2008
  • 41,812 POSTS
Did the replacement fuel pump comes complete as an assy or just the pump was replaced?
Are you still getting the same trouble codes?
Aug 18, 2016 at 11:42 PM
CAMUMA34
Entire assembly and getting same codes and now new codes
p0223 tps high volt
P2135 tps volt
P0102 maf low volt
Do u think it's the ecm?
Aug 19, 2016 at 12:39 AM
KHLOW2008
  • 41,812 POSTS
Nope, there seems to be a problem with the Throttle Position Sensor, (TPS) as per the codes showing. check the TPS wire connector for looseness or contaminations or broken wires.
Aug 21, 2016 at 11:18 AM
