no starter operation engine does not crank over?
111,111 MILES • 6 CYL • AUTOMATIC
USOGEE209
I replaced the HVAC btt fuse and now my dash board lights won’t come on and car stays on for a couple seconds then shuts off?
Nov 13, 2020 at 10:01 AM
  • 110,251 POSTS
The problem started when the fuse was replaced? Do you mean the HVAC battery fuse? See attached pic.
If that is the one you replaced, check to make sure you didn't bump the fuse for the PCM. See pic 2. Also, I need to know if the fuse you replaced has blown again. if oaky it sounds like the battery is weak or the starter has gone out but to be sure lets check out these guides, they can help us fix it
and
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Nov 13, 2020 at 12:07 PM
USOGEE209
Yes, the Ipc HVAC batt fuse and it haven’t blown again. Where do I locate the PCM fuse?
Nov 13, 2020 at 3:17 PM
  • 110,251 POSTS
The PCM fuse I referenced is in the same panel as the HVAC fuse. See pic 2 above.
Okay, we need to determine if there is spark and fuel to the engine. One is likely missing. That will help us narrow down what needs to be checked.
Take a look through this link and let me know if it helps. Also, see if the engine starts for a couple of seconds using starting fluid. If it does and then stalls, we lost fuel. If it doesn't, then there is likely an ignition issue.
Nov 14, 2020 at 11:12 AM
USOGEE209
thanks for the guides the starter was bad all fixed this site is great!
Nov 16, 2020 at 12:18 AM
  • 110,251 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Nov 19, 2020 at 9:18 AM
