Car will not start up
15,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
STILIAN
Hi. I am having a problem starting my engine. I had left my car in the sun and to be fair it was very warm. I felt it immediately since I got it than the inside temperature was around 40-45 Celsius. Anyway, I got the key in tried to fire it up,, it didn't load the battery at all. All I was hearing was a crack crack noise from the inside and a message from the panel " Radiator overheat ". Any tips what should I do or not do ? Thank you
May 23, 2019 at 11:56 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Although it was hot outside, the engine operates at around 100 Celsius. Unless the engine was just turned off and was overheating prior, 40 Celsius is nothing to worry about.
I need to explain. This vehicle isn't offered in the US, so my technical information is very limited. However, some basic things to check would be to confirm the coolant level is full and make sure the cooling fan is working properly. If the coolant is full, the engine sat for some time prior to the problem, and the light still comes on, I would next suspect an issue with the coolant temperature sensor.
Here are a few links that may help you. Take a look through them.
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
https://www.2carpros.com/articles/engine-cooling-system
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
https://www.2carpros.com/articles/replace-electric-fan-motor
______________________
Now, since the engine will not turn, you really should check the battery. Here is a link explaining how to load test one. Try this to confirm the battery is good. Remember, heat is very hard on a battery.
_______________
Again, I'm sorry I have no specific info on this vehicle. However, most vehicles function the same, so first check the things I mentioned and let me know what you find.
May 25, 2019 at 12:48 PM
