Car will not start or turn over
2002 LEXUS ES 300
200,000 MILES • V6 • 2WD • AUTOMATIC
TIFFANY BROWN
When I try starting my car it does nothing, I don't even hear the fuel pump,no click, nothing. All my lights,locks,and windows work so I still tried jumping it. When I put key in ignition the door locks lock and unlock which normally don't do. Feel like the car is shut down maybe. Help I need my car.
Mar 22, 2020 at 11:54 AM
  • 110,244 POSTS
Do me a favor, see if it will start if you place the gear in neutral. Let me know what happens. If it doesn't do the following.
If you look at picture 1, it shows fuses I need you to check. Now, at the top of the picture I highlighted what is called a fusible link that supplies power to the two fuses I circled. So, in addition to just checking the fuse to make sure it's good, you need to also check for power. If there is no power, the fusible link may have failed.
A fusible link functions as a fuse, but looks like a regular wire. So, the only real way to test it would be to check for continuity (if power can pass through it). We will cross that road if the fuses are good and don't have power.
The second pic shows the starter relay. What I suggest is to switch it with a different one with the same part number to see if that changes anything. If there isn't one with the same part number, I will provide the directions for checking a relay.
_______________________________
I have to be honest, based on what is happening with the locks, I have suspect there is a bad connection at the battery or corrosion causing a poor connection. So, make sure the terminals are clean and tight and the battery is fully connected. Also, check to make sure the grounds from the battery are in good condition.
Here are links to help with the testing:
Mar 22, 2020 at 1:40 PM
TIFFANY BROWN
I put in neutral still nothing. I've checked the fuses but yesterday I went to start it and it crank right up. I hear the fuel pump come on but the locks still doing same. I took negative battery cable off and when I put it back on my alarm didn't go off like it said it would.
Mar 23, 2020 at 10:02 AM
  • 110,244 POSTS
Were the terminals clean and tight? Is it working normally now? I ask because the idea that you were checking fuses, relay, disconnected the battery and so on you may have provided a new connection.
Mar 23, 2020 at 1:10 PM
TIFFANY BROWN
No it's not earlier it wouldn't start but about 3 hours later it crank right up. Very frustrating and confusing.
Mar 23, 2020 at 4:27 PM
  • 110,244 POSTS
Has it continued to start now or are you back to the no start?
Mar 24, 2020 at 3:26 AM
TIFFANY BROWN
Sat for 4 hours at the store with it not starting. Had it towed then 2 hours later started right up.
Mar 24, 2020 at 2:19 PM
  • 110,244 POSTS
Hi, Tiffany. When it didn't start, did the starter engage?
Let me know. I wish I had an easy answer. Car's can be very difficult, especially when it's intermittent. Also, when it wouldn't start, did you check or move to inspect any of the fuses or relays?
Mar 24, 2020 at 2:27 PM
