Car wont start only when cold. Will turn over.
173,000 MILES • 2.2L • 4 CYL • AUTOMATIC
CRAZYBABI4LYFE
My car starts and runs fine, right up until it turns about 55 degrees outside. If it sits in the sun, it will start, im assuming that is because it is a darker car and the sun warms it up enough. It is not cold enough to not start, it turns over, just will not catch. I took it in to be looked at. They replaced the fuel pump and the extra screen needed for my car and that didn't change anything. They said the spark plugs are fine, and that the timing is done by the computer, not a timing belt. I am at a loss, and i really think they have no idea. They cannot reproduce the issue because i only really have the issue at night when i get off of work, late when it is cold. If it is warm, it will start up every time. it makes no sense and i am at a loss.
Nov 9, 2014 at 4:25 AM
JDL
  • 16,098 POSTS
With intermittent issues, you have to test when problem is ongoing. If it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure. I realize some vehicles don't have a Schrader valve, in that case you tee into the supply line.
I would want to see if system is running rich or lean, when the problem is ongoing? If temp related your coolant temp sensor could cause issues. I'm not saying throw parts at it.
If you think it is running lean, you could add some flammable spray to the intake, see if it helps? Anytime you use a flammable spray there safety issues. Safety is your responsibility.
You can take air-duct loose from throttle body, open throttle valve, spray just a little. Stand back away from vehicle, have helper turn key to crank. The person in the vehicle is protected by hood and windshield. Like I said, if something blows-up, that's on you.
Nov 9, 2014 at 5:39 AM
