Key in ignition will not start the car. The immobilizer light goes on and is blinking.
Nov 26, 2017 at 4:57 AM
KHLOW2008
✓Experienced Mechanic
The immobilizer is preventing the engine from starting. Try arming and disarming the security system first. Ensure you have the correct key and use the spare one if you have it. Battery must be sufficiently charged as a weak battery would result in non starting and triggering the security system.
Nov 26, 2017 at 12:21 PM
PETER SCOTT
MEMBER
So how on earth do I do that?
Nov 26, 2017 at 6:58 PM
KHLOW2008
Have the battery tested. Ensure it is good and sufficiently charged. Try a jump start.
Lock all doors and use the key to unlock or if you have a fob, use it to arm and disarm the security system.
