Car will not start after water pump replacement
190,000 MILES • 6.0L • V8 • AUTOMATIC
NICKOLASMIKE
  • 7 POSTS
I had a water leak from my water pump I replaced the pump only unplugging the hoses that went to it to do so . Now my car won’t crank well it will very rarely but not for long. I was getting a crankshaft sensor code replaced it and still won’t crank. I’m not sure where to go with this next. Vehicle listed above is an XL 1500 Denali 6.0 vortec.
Nov 28, 2020 at 3:27 AM
NICKOLASMIKE
  • 7 POSTS
So I found out my ECU got a little bit of water in it, now it’s throwing up throttle sensor codes.
Nov 28, 2020 at 6:46 AM
NICKOLASMIKE
  • 7 POSTS
Could these random codes be a result of a failing ECU?
NICKOLASMIKE
  • 7 POSTS
Vehicle is in limp mode. codes won’t clear throttle body circuit and throttle sensor codes on now.
Nov 28, 2020 at 10:21 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It will help if you could provide us with the code numbers. This way we can give you the repair information that correlates with the code numbers. Get back to us with the information and we'll go from there. Hope this helps and thanks for using 2CarPros.
Nov 29, 2020 at 4:35 AM
