car wont start after replacing cran seal
98,316 MILES
KASH316
I replaced crank seal and know car wont start had wires in wrong place and distributor 180 retimed it and it threw two codes 13 and 34 which in the manual is knock sensor and coolant temp sensor
Apr 23, 2013 at 7:30 AM
JDL
  • 16,098 POSTS
Do you have good cylinder compression?
Apr 23, 2013 at 8:12 AM
KASH316
Yes.each time I check spark plugs are soaking wet and I have two codes
Apr 23, 2013 at 10:12 AM
JDL
  • 16,098 POSTS
Were you having this problem before you worked on it? Double check your work, maybe you knocked a connector loose, somewhere? Use a spark tester, see if you have any spark at the spark plugs, engine cranking.
If you suspect the coolant temp sensor, use a digital multimeter, at the two wire connector, key on, should be around 5 volts.
Apr 23, 2013 at 11:22 PM
