Engine not starting after overheating
140,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
PEGGY MENDOZA
I just bought the car listed above (lx), test drove it and it ran fine. Guy told me to replace the radiator because the cap was stripped but sold new okay to drive home. 4 miles later it overheated, pulled over to the side of the road to let it cool down, now it won't start. Called a wrecker to tow it home, replaced radiator and it still won't start. It does turn over. My son put a code reader on it and it says misfire in cylinders 1 and 3. Is it worth fixing with so many miles on it? And what would cause out not to start?
Thanks
Jun 7, 2021 at 2:57 PM
BORIS K
  • 836 POSTS
The symptoms you describe point towards a possible blown cylinder head gasket.
The overheating could have caused the cylinder head to warp.
Here is a link that explains what is cylinder head gasket is and its function:
https://youtu.be/jBidX6le0qQ
A quick check is to remove the spark plugs and check if they are moist with coolant.
While the spark plugs are removed also crank the engine over and check if any coolant sprays out of the spark plug holes.
Checking an engine not starting basics:
If no coolant is evident then next check if there is spark at the spark plugs.
How to check for spark:
https://youtu.be/69Km8qAKJ18
If you have spark then next to check would be compression
How to check compression:
Please let us know how you get along.
Cheers, Boris
Jun 8, 2021 at 12:31 AM
PEGGY MENDOZA
Thanks! No coolant but there is oil in one spark plug well. Checking relays and grounds right now. Valve cover gasket, plugs and wires, distributor cap are on the way.
Jun 8, 2021 at 12:38 AM
  • 110,248 POSTS
I noticed it has been a few days since we made contact with you. Have you made any progress? As far as the oil in the spark plug wells, that could have damaged the wires, but shouldn't have caused a no start.
As aforementioned, it could be a head gasket. Is it possible for you to record the engine cranking so I can hear it? Hopefully, if there is low compression in a couple of the cylinders, I'll be able to recognize it.
Next, most times when a vehicle fails to start, it is related to an ignition issue (no spark to plugs) or a fuel-related issue. See if it starts for a couple of seconds using starting fluid and then stalls. If it does, then we know it's fuel-related. If it doesn't, then we need to check for spark at the plugs.
Here are three links you may find helpful. One explains the most common causes of a crank no start condition, one is how to check spark, and the other deals with checking fuel pressure.
If you suspect it is a head gasket, we will need to check engine compression to confirm. Here is a link that explains how it's done:
I attached the compression specs below for this vehicle. Again, not always, but most times, I can tell if there is a timing or compression issue just by hearing it crank. So if possible, upload a video of it cranking for me to hear.
See Pic below.
Jun 10, 2021 at 11:16 AM
