Car will not start after engine replacement
140,000 MILES • 6 CYL • AUTOMATIC
KMB24
  • 19 POSTS
I had to replace the engine of my car because the other one got overheated and the heads did not work. Mechanic said old engine had not fix. Got a new engine from a 2006 car. The car will not start. Mechanic says the code in machine say something about the computer being locked.
Feb 3, 2019 at 11:23 AM
Good morning,
What is this code that has set?
Please give me as much information as you can.
Feb 3, 2019 at 5:56 PM
KMB24
  • 19 POSTS
345, 335 and the mechanic says that something about the coils not having current.
Feb 4, 2019 at 3:22 AM
Hello again.
The 335 code possibilities are below
P0335
Descriptor
Probable Causes
Crankshaft Position (CKP) Sensor
Signal Plate (Flywheel)
345
P0345
Descriptor
Probable Causes
Battery Voltage Low
Camshaft (Intake)
Camshaft Position (CMP) Sensor
Starter Motor
Starting System Circuit
I am very concerned with this. Both codes being set tells me there may be a timing chain issue. Did he check the compression?
Feb 4, 2019 at 5:02 AM
KMB24
  • 19 POSTS
Yes he says everything is good, he says theres no current in the coils, theres no spark in the spark plugs.
Feb 5, 2019 at 1:41 AM
Does he have voltage to the cam and crank sensors?
These codes have no connection to the coils.
Feb 5, 2019 at 1:46 AM
KMB24
  • 19 POSTS
The mechanic says the computer of the car does not send signal to the engine because everything is good. He says he thinks it is locked.
Feb 5, 2019 at 11:25 AM
No he is wrong.
It sounds like he does not know what he is doing.
Feb 5, 2019 at 11:30 AM
KMB24
  • 19 POSTS
What do you think it can be? I need help ASAP. I already spent a lot of money on the car. He thinks it is something with the computer, because he says there is no signal sent to the spark plugs from the computer. He said he checked compression, time belt, and everything. He said he does have current on the coils. He also found this:
Feb 5, 2019 at 11:37 AM
KMB24
  • 19 POSTS
I meant to put he says there is no current on the coils*
Did he check all the fuses?
Feb 5, 2019 at 4:25 PM
Here are wiring diagrams for him to view and needs to check the red wire to the coils.
Feb 5, 2019 at 6:13 PM
KMB24
  • 19 POSTS
Sorry about answering late. Mechanic was trying to figure what was going on he said he checked the harness and that there isn't any power? He said he going to talk to a technician.
Feb 7, 2019 at 12:31 PM
You really need to get this car to someone who can diagnose the issue. It sounds like they don't know what they are doing.
Feb 7, 2019 at 5:04 PM
KMB24
  • 19 POSTS
What do you think maybe the issue? So i can let him know. And who would be the best at it?
Feb 7, 2019 at 10:08 PM
The wiring needs to be checked. All the signals need to be checked and powers and grounds.
Feb 7, 2019 at 11:59 PM
