Car Won't Start After Being Driven
137,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
RADTONE
Car won't start after being driven. Get in start it, drive it around, park, shut car off, go to start it won't start. When you turn the key you can hear the starter solenoid ' click ' but starter won't turn. Now if I let it cool or jump it the car will turn over. Heat related problem? I have changed the battery, starter ( twice ) battery cables, battery cable terminals. I don't know what else I can do, even the mechanic is puzzled. No lights come on the dash. I even checked the alternator output, it reads 14.5volts.
Jul 24, 2014 at 10:27 PM
HMAC300
  • 48,601 POSTS
make sure battery has a good ground to engine and body, then check the starter relay and the items in the 2 pics. one being a fusible link may be fried.
Jul 24, 2014 at 11:25 PM
