Car will not start
177,000 MILES • 4 CYL • 2WD • AUTOMATIC
DESI LEEPER SR.
I was stuck in the snow, and I was giving it a lot of gas pretty much redlined it for less then a second and the car just cut out and shut off. The battery light comes on and the starter starter started smoking a little bit when I try to start it but it doesn't do anything, the lights come on but it wont crank.
Jan 29, 2021 at 5:22 AM
  • 110,248 POSTS
When the starter smoked, was the engine actually turning? Or, is there a click and then nothing happens?
If you had it at redline, something may have happened internally in the engine. Let me know if the engine turns at all so I know what to do next.
If it cranks but doesn't start, take a look through this link and let me know if it helps:
I will watch for your reply.
Jan 29, 2021 at 12:23 PM
DESI LEEPER SR.
No, the engine wasn't turning when the starter started smoking. Yes, it just clicks and nothing happens.
Jan 29, 2021 at 12:53 PM
  • 110,248 POSTS
What I need you to do is see if you can turn the engine by hand. Get a large breaker bar and socket, place it on the crankshaft pulley bolt and see if you can turn the engine by hand.
I attached a pic below showing you what bolt to place the socket on.
Let me know what you find.
Jan 29, 2021 at 1:19 PM
