Car will not start
100,000 MILES • 2WD • AUTOMATIC
GREGGOCAN
It was really cold last night, around 10 degrees. Today it tried to turn over and then rapid clicks. Boosted it off, let it run a bit shut it off and wouldn’t restart. I think it’s the battery. Would it have shut off while it was running if it was the alternator?
Jan 29, 2021 at 3:26 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It could be one of two things. Either the battery is not holding a charge, Or the alternator is faulty and not charging the battery. Auto parts stores will test both for free. Here are tutorials showing how to battery load test and an alternator test:
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
https://www.2carpros.com/articles/how-to-replace-a-car-battery
https://www.2carpros.com/articles/how-to-replace-an-alternator
You will need to remove the serpentine belt to remove the alternator. Here is a tutorial for that as well:
https://www.2carpros.com/articles/replace-serpentine-belt
I've attached picture steps below on how to remove and replace the alternator on your car. Hope this helps and thanks for using 2CarPros.
Jan 29, 2021 at 6:00 AM
