Car will not start
171,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
SYLVER
  • 21 POSTS
My car will not start. It stalled out while driving , it had to be towed. I had to replace the battery with a new one because it was stolen while it was on the side of the road. The starter is engaging and the engine is spinning. I did a fuel pressure test and it came out to 50 psi. I believe it is the ignition system. Can you help me out determine what could be the problem?
Jun 21, 2017 at 6:29 AM
  • 55,797 POSTS
It sounds like the crankshaft angle sensor has gone out. Here is a guide that will show you what you are in for when replacing the sensor and a diagram (below) on how to fix it on your car.
(Diagrams Below)
Cheers, Ken
Jun 24, 2017 at 3:48 AM
SYLVER
  • 21 POSTS
I changed the sensor and it still won't start
Jun 30, 2017 at 9:39 AM
  • 55,797 POSTS
When the engine is not starting do you not have fuel pressure or spark?
Please let us know what you find.
Cheers, Ken
Jul 2, 2017 at 11:35 AM
