No crank no start issue
2,995,000 MILES • 6 CYL • 4WD
MISS1E
I sprayed what i thought was to be a mass air flow sensor instead it was the MAP sensor n my car will not start and won't crank either.
May 18, 2022 at 2:41 PM
  • 55,746 POSTS
It sounds like the battery went bad. To be sure this guide can help you to load test the battery without the use of tools or equipment.
Here is a video to help you as well:
https://youtu.be/oHTbC73FAgU
This guide will show you what to check for if the engine is not craning over but I really think it is a battery issue.
Please run down these guides and report back. Let us know what happens and please upload pictures or videos of the problem.
May 19, 2022 at 5:14 AM
