i dropped the steering column and pulled the dash to replace the heater core. I put it back together and it wont start. key turns ,accessories work but it wont crank. i took it apart and everything except the ignition /shifter interlock cable looks good. this cable has a housing on it that has broken. will this keep it from starting? or does this just allow the shifter to be moved from park when the key is turned which it still does?
Nov 29, 2016 at 6:35 AM
