Cranks will not start
222,000 MILES • 2.5L • V6 • 2WD • MANUAL
JFERS13
Drove car and when parked car wont start anymore. it sounds like flooded. cranks but wont start. Found piece of cover in timing belt.
Aug 25, 2019 at 5:22 AM
  • 110,248 POSTS
Welcome to 2CarPros.
What did you find on the timing belt? Is the belt broken or has it jumped time? Does it sound different when the starter is turning the engine?
If the belt is the issue, the good news is that this is not an interference engine, so part replacement will take care of it. However, we need to determine what exactly has happened.
Take a look at the this link first:
If that doesn't help, we need to determine if there is spark and fuel to the engine.
If there is spark and fuel, then we have to check engine compression to see if there is a timing issue.
https://www.2carpros.com/articles/symptoms-of-low-compression
___________________________________________________________________
Let me know what you find. I can walk you through the timing belt if it is needed.
Take care,'
Aug 26, 2019 at 10:52 AM
