Does not start, recently had crankshaft sensor replaced?
185,000 MILES • 2.0L • 2WD • AUTOMATIC
ALECHNER7985
recently had crankshaft sensor replaced. car ran fine, then started overheating. This time it overheated completely; and the car shut off. i let cool down for 2 hours would not start back up. had it scanned it was giving the code for a crank shaft sensor. so replaced crank shaft sensor again, also replaced cam shaft sensor and one other sensor and the relay. car still won't start. has a low crank, like a whining crank but will not start.
Aug 13, 2024 at 11:24 PM
  • 55,721 POSTS
Hmm, the noise cranking is the concern. If the engine gets severely overheated, it can cause the engine to lose compression. Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on.
In the meantime, you can run a compression test by following this guide:
This video can help as well:
https://youtu.be/lXLJbuAZ4CE?si=n3gAvTwxyD7XPiWD
Please go over these guides and get back to us.
Aug 14, 2024 at 3:40 AM
