Car will not start after running out of gas (refueled)
160,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
KEN PEARSON2
Ran car out of gas, put fuel in it still would not start. Replaced fuel pump, fuel filter and checked to see if the relay switch clicked when key was turned on. Still no fuel. Pour a little gas into it it will run until the gas burns off. Checked fuel pressure regulator also. Got any ideas?
Jul 28, 2018 at 2:32 PM
Good afternoon.
I attached a wire diagram for you to view. Check for power to the relay. There is a fuse listed and be sure there is power to both sides.
The PCM controls the control side of the relay.
Jul 29, 2018 at 6:53 AM
KEN PEARSON2
Thank you, but we have it fixed. Ended up being a broken wire.
Jul 29, 2018 at 11:08 AM
  • 55,770 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Jul 29, 2018 at 11:09 AM
