Car will not start
10,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DENNIS GERARD
  • 10 POSTS
Car was running went into house came out three minutes later and it stalled. Gas is good , battery good. turn key on and off three times and gone no codes flashing. Tried some starting fluid in intake and nothing. turns over but will not start
Jan 20, 2018 at 6:38 AM
CARADIODOC
  • 34,415 POSTS
First listen for the hum of the fuel pump for one second when you turn on the ignition switch. If that is okay, check for spark. Chances are real good you will find spark is missing. The real common suspect is the pickup assembly in the distributor, just under the rotor. It is a black plastic disc with a three-wire connector.
Jan 20, 2018 at 2:22 PM
DENNIS GERARD
  • 10 POSTS
replaced the pickup assembly and still no start no spark
Jan 24, 2018 at 11:07 PM
CARADIODOC
  • 34,415 POSTS
I see you posted a new question. (There aren't that many '84 Daytonas around). I posted more details on your other question, so lets stick with that one.
Jan 25, 2018 at 9:38 AM
DENNIS GERARD
  • 10 POSTS
thank you
Jan 25, 2018 at 10:13 AM
  • 55,748 POSTS
I used to drive one of these cars :)
Jan 28, 2018 at 6:17 AM
