Engine shut off on its own and will not start
25,000 MILES • AUTOMATIC
EMILY1234
I warmed up my car this morning and it turned off by itself and it won't start properly. It's not the battery because I just brought a new one and the lights green and I checked the oils and it seemed fine. I need my car right away.
Dec 1, 2020 at 6:26 AM
  • 110,248 POSTS
When you try starting it, does it do anything? For example, does it start and then stall? Does it crank and never even try to start? I ask because there are a few things that can cause this issue. However, they are usually associated with either a fuel or ignition related issue.
Please understand, we don't have this model in the US, but I think it is the same as our Ford Escape. Please provide the engine size so I can check and see it is the same.
Next, if it is possible, record what it is doing and upload it for me to hear.
Until I hear back from you, take a look through this link and see if there is anything that is helpful. It discusses the most common causes for a crank no start condition.
Dec 1, 2020 at 10:22 AM
