My vehicle will not turn over. I try turning it on and it sounds like it's trying so hard but can't. Every now and then it feels like the fuel does ignite but only for a second. The fuel pump turns on, it has new spark plugs, ignition coils should be fine. It has one new ignition coil that i have swapped around with the others to see if that works. Before it decided to not crank anymore I had to pump the pedal to get it to turn over. Now that wont work. Battery is fine, fuses are fine too. Air filter is good. I'm not sure what's going on with it.
Aug 30, 2019 at 9:07 PM
