Engine not cranking over
100,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
JONATHANBROWN
Went to the store car started and ran great. the next morning it wouldn't start. thought it was the battery. tried to jump start it; nothing just clicking. changed the starter, same thing just clicking...
Jul 7, 2020 at 11:50 AM
  • 110,248 POSTS
Is the clicking coming from the starter? Are you sure the battery terminals are clean and tight?
The starter places a heavy load on the battery and if the connections are loose or corroded, it can cause this. Do me a favor, here is a link that explains how to load test a battery at home. It's really simple to do. Try this and let me know the results.
Let me know what you find.
May 17, 2021 at 11:46 AM
JONATHANBROWN
Already checked the battery and tried to start the car with the battery charger on the battery. same thing, no start. I took the battery out when I changed the starter so that would have reset any security issues, I think. there were no codes that came up when we checked the computer. there was an odd burning plastic smell earlier in the day while we were driving, but I can't find any burnt wires and all the fuses look good.. same with the spark plugs they all look good...
  • 110,248 POSTS
The burning smell has me concerned. I need you to confirm something for me. I need to confirm that the starter is getting the correct power. On the starter, there is a large wire that comes straight from the battery. It always has 12v. There is a smaller wire that only gets 12v when the key is in the start position. I need you to confirm that both of those things are happening.
  • 55,748 POSTS
It sounds like the starter relay (ST relay) is not working correctly. here is a guide to help check it with the starter wiring diagrams so you can see how the system works and the relay location as well:
