Car will not start
186,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
RICH24
Tried to start get nothing. Will not turn over, my needles jump all over. It was starting before this but when turned the key to start it would be a weak start, but now i get nothing getting clicking noise and needles jumping.
Apr 28, 2018 at 11:10 PM
Good morning.
It sounds like low voltage from a weak battery. You need to check the voltage at the battery with a volt meter. You need 12.6 volts for a fully charged battery.
Start there.
Apr 28, 2018 at 11:19 PM
Do you have a voltmeter to do the voltage check?
Apr 29, 2018 at 5:18 AM
RICH24
No, I do not have volt meter. I tried a jump box got nothing connected jumper cables to a v8 let it charge for five minutes still got nothing when turning key over. Could it still be a weak battery?
Apr 29, 2018 at 5:35 AM
Yes, if you have a shorted battery it will not take a jump.
You can get a cheap meter at a parts store or Harbor Freight. That will help us a lot in helping you.
Apr 29, 2018 at 5:39 AM
RICH24
Okay thank you. I will purchase volt meter.
Apr 29, 2018 at 5:41 AM
Okay, let me know so I can guide you on the checks.
Apr 29, 2018 at 5:45 AM
WRENCHTECH
  • 20,760 POSTS
Sounds like a battery supply issue. Have the battery charged and then tested for health.
Also check all the cable connections.
May 1, 2018 at 10:44 AM (Merged)
