Car will not start after GPS unit was removed
140,000 MILES
DOYLE STEVENS
The GPS unit was taken off and now the vehicle won't start. I have bypass the ignition hook the starter straight to the battery. the car would start, but would only run for a minute. will not start with the key.
Jan 8, 2020 at 6:33 AM
Good afternoon,
You triggered the theft system by removing this unit.
You cannot bypass it. It will stay this way until the GPS is disabled in the PCM.
That will have to be done with the factory scan tool.
Jan 8, 2020 at 6:42 AM
DOYLE STEVENS
Thank you. can you tell me where I can get this done at?
Jan 8, 2020 at 7:18 AM
Any shop that has a TECH 2 scan tool should be able to perform this. Otherwise, you would need the dealer, if they will do it. They are touchy about disabling safety features.
Jan 8, 2020 at 7:20 AM
