So let's check the voltage at starter solenoid with a helper cranking the engine. Make sure if you are not using a jumper wire and you are underneath the car it is properly secured. Here is a link for you to go to for how to have your vehicle properly secured:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Also, you will be using a multi-meter to do this, so here is another link for you to go to if you are unfamiliar with how to use one:
In the diagrams down below I have included a wiring diagram of your vehicle's starting system for reference. The connection you will taking a voltage reading on is the light green or yellow/gray wire on the left of the starter on the wiring diagram. Please get back to us with what you find out and we will go from there.
Thanks,
Alex
2CarPros
Images (Click to enlarge)
Jun 29, 2021 at 2:14 AM
