Car will not start
200,000 MILES • 3.0L • 6 CYL • 2WD
TARADACTYL
  • 5 POSTS
My husband ran my car out of gas. While it was sitting on the side of the road, someone removed the ignition lock cylinder. (So a screwdriver would start it.) My problem is it won't start now. It sounds like it wants to but won't. My first question is, would it turn over like it wants to start or would the anti-theft system make no sound all. My second question is, does the anti theft system stop the fuel pump from running?
Jan 27, 2021 at 1:01 AM
SEVAG P
  • 405 POSTS
hello,
First step we must check the fault codes to narrow down our problem.
yes anti theft system can cause to engine not start,
check our link below how to reset the immobilizer check the Toyota section.
https://www.2carpros.com/articles/how-to-reset-a-security-system.
If the engine still not running after the procedure use a scan tool check for fault codes and send to us to guide you for proper diagnosis.
check our link below how to check fault codes.
Jan 28, 2021 at 3:32 AM
TARADACTYL
  • 5 POSTS
The "how to reset a security system" link doesn't work , could you repost it for me please?
Jan 30, 2021 at 11:13 PM
SEVAG P
  • 405 POSTS
hello,
sorry for the link, i repost it.
thank you
Jan 31, 2021 at 2:06 AM
TARADACTYL
  • 5 POSTS
I'm charging my battery and I reassembled the ignition. there were no broken wires but the hollowed out the cylinder. My key still can turn it because of the notch in the back of the cylinder. Security light is flashing. My fob still locks and unlocks the doors though. Once the battery is ready, I'm going to reset the anti theft system.
Feb 1, 2021 at 2:36 AM
TARADACTYL
  • 5 POSTS
Here's a pic of it after I reassembled it. When I open the door, the green light goes on for a few seconds. So, it's still working! Keep your fingers crossed!
Feb 1, 2021 at 2:47 AM
SEVAG P
  • 405 POSTS
hello,
yes perform the reset procedure for security system, and let us know what happens with you.
thank you.
Feb 1, 2021 at 4:24 AM
TARADACTYL
  • 5 POSTS
I'm so sorry Sevag, I forgot to get back to you. Yesterday, after I charged the battery and reassembled the ignition, I put the key in the cylinder and turned it, and it started right up! I'm so thrilled! Thank you so much for your help. I appreciate your patience, and will tell all my ladies about 2carpros.com. you rock SEVAG!
Feb 2, 2021 at 1:50 AM
SEVAG P
  • 405 POSTS
you're always welcome here and thanks for your reply.
Feb 2, 2021 at 2:08 AM
