Car will not start after shutting off while driving
198,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
CAOPHIL
running normally on freeway , suddenly the engine slow down and stops in the traffic. Have car towed to my home. Filled up the gas tank and car won't start.
Mar 24, 2020 at 11:33 PM
Good morning.
Did you run out of fuel?
If you did, you most likely damaged the fuel pump. The gas is both a coolant and lubricant for the pump.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Can you hear the pump run with the key on?
Mar 25, 2020 at 12:00 AM
