car cranks but it wont start
2,000,000 MILES • 4 CYL • MANUAL
CEHICKS
engine cranks but wont start. I checked fuel pump relay it tests good. have twelve volts at fuel pump relay. relay activates with ignition switch. but I get no voltage to fuel pump.
I also checked spark to plug number one and I get spark.
The fuel pump was bad and I changed it. I also tried a new fuel pump relay to no avail.
any suggestions?
Nov 3, 2016 at 3:51 PM
HMAC300
  • 48,601 POSTS
if the relay works and no power to pump it is either a contact problem or wiring is broken someplace so check for that. if relay is not sending power then try resetting security sytem. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Nov 4, 2016 at 12:10 AM
CEHICKS
thanks I found the location of the problem. the jack that plugs into the fuel pump assembly has either a broken wire or is just not making good contact.
Nov 5, 2016 at 10:49 AM
  • 55,782 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Best, Ken
Nov 7, 2016 at 1:22 AM
