no starter
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHELBY LOLA WILSON
Everytime I try to start my car I turn the key but it makes no sound at all. The lights work on the inside and outside of the car. The windows and locks work. I was thinking the starter but I really don't know.
Sep 17, 2019 at 11:37 AM
Good evening,
Yes, it could be but must be confirmed.
It sounds like the battery is weak or the starter has gone out but to be sure lets check out these guides, they can help us fix it
and
Did you try putting it in neutral and trying it again?
I will attach a wiring diagram for you to view as well.
Does the theft light come on and go out after about 10 seconds with the key on?
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jan 29, 2021 at 1:55 AM
SCGRANTURISMO
  • 4,897 POSTS
Okay, this could be a problem with the Run/Crank Relay which is located in the Under Hood Fuse Block. I have included a wiring diagram of your vehicle's starting circuit in the diagrams down below as well as a diagram and callout for the Under Hood Fuse Block. You can either swap the relay for a known good one or take a voltage reading with a helper cranking the ignition key at pin #86 of the Run/Crank Relay. I have also included a diagram of a 4 Pin relay for you in the diagrams down below as well. Either way please get back to us with the results and we can go from there.
Thanks,
Alex
2CarPros
