trying to start the car it just does a click click click sound?
200,036 MILES • 6 CYL • 2WD • AUTOMATIC
AMANDA SALAS
When trying to start the car it just does a click click click sound. I have replaced the starter, battery and negative battery cable. It still only does the click click click when trying to start it.
May 22, 2019 at 12:59 PM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like it could be a problem with your battery. You said you replaced it but let's confirm that it hasn't been drained from trying to start the vehicle. Could you take a voltage reading across the terminals for me. You will need a multi-meter to do this so I have included a link down below for you to go to if you are unfamiliar with how to use one.
and
Please get back to us with your reading and we will go from there.
Thanks,
Alex
2CarPros
Jun 25, 2021 at 5:28 AM
AMANDA SALAS
This is the sound it's making when trying to start it.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Can you please take a voltage reading for me at the starter solenoid of the black wire with a yellow stripe? I have included a wiring diagram of your starting system with the wire hilited, Please get back to us with what you find out.
Thanks,
Alex
2CarPros
