Car won't start
54,000 MILES • V6 • 4WD • AUTOMATIC
DEEOWNSBY
My car keeps telling me to push the brake when I'm already pushing the brake to start my car
Sep 23, 2025 at 12:44 AM
AL514
  • 5,700 POSTS
Hello, I have found these with a blow fuse for the brake pedal switch circuit cause this, because of a fault with the rear tail light circuit, it was actually the bulb sockets that had a recall part. But the tail lights circuit shorting out blowing the brake light fuse, like small like a 7.5Amp fuse. Hyundai/Kia have a lot of the same issues. Sounds crazy but thats what it was. I replaced both rear lamp socket assembly with update harnesses, clear the codes for that circuit and the brake pedal switch circuit. Do your brake lights come on when you press the brake pedal?
Sep 23, 2025 at 2:29 AM
AL514
  • 5,700 POSTS
I will pull up a wiring diagram to see how the vehicle is set up, heres some guides to help with fuse testing.
Sep 23, 2025 at 2:31 AM
AL514
  • 5,700 POSTS
Here are all the Brake pedal switch circuits, diagrams 1,2 (pg1 top & bottom)
Diagrams 3-5 are the oem Brake Pedal circuit wiring diagrams.
Sep 23, 2025 at 3:14 AM
