Car will not start
230,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
TEEGANSOPHIA
I changed the starter on my car but it’s not starting. it sounds like it’s going to start but won’t start.
Oct 12, 2019 at 1:25 PM
  • 110,248 POSTS
Welcome to 2CarPros.
If the starter is turning the engine but it refuses to start, chances are either there is a fuel or ignition spark related issue. Lets start by testing for both.
First, here is a link that explains in general the most common causes of a crank no start condition:
Here are the links explaining how to check for spark and fuel to the engine:
If it is at all possible, upload what is happening. If I can hear it, I may be better able to recognize an issue.
Let me know if this helps or if you need help.
Oct 13, 2019 at 1:58 PM
TEEGANSOPHIA
Found out the problem. It was the engine need new engine.
Nov 8, 2019 at 10:42 AM
  • 55,627 POSTS
Glad you could get it figured out. Use 2CarPros anytime, we are here to help. Please tell a friend.
Nov 8, 2019 at 10:43 AM
