Car wont start
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
KALUB ROBINSON
When i try to start nothing no crank . if i use the purple wire across to b+ it tries to start but doesn't. The key sticks in ignition gas gauge and temp gauges do not work. Service anti theft. stability system comes on the dash screen. When all this started i pulled into parking. Lot and parked on downhill slope and got to close to curb. When i let go of brake it jammed the car in park and key would not release. Also i had the recall done but they could not start and i was to broke to do diagnosis. I am on fixed social security and cannot afford dealership mechanics. The car has been a lawn ornament for nine to ten months. Bought a new heavy duty battery. Not the problem. Please advise. Thank you so much.
Aug 12, 2016 at 4:35 PM
HMAC300
  • 48,601 POSTS
it sounds pretty much like the security system is engaged not allowing this to start. if no owners manual look online on how to reset it for your car. if that does not work a mechanic at a garage will have to put his scanner on it to see what is wrong with it.
Aug 12, 2016 at 10:49 PM
