Engine will not start up?
155,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
TAUTVYDAS JAGUCIANSKAS
  • 7 POSTS
Went out to start my car, at first it started up normal, but it was losing revs until it shut down. Tried starting the engine again and it just cranks, but won't start. I changed out the spark plugs about a week ago, the fuel pump works, air system is unclogged. what else could be causing issues?
Mar 25, 2019 at 5:59 AM
SEVAG P
  • 405 POSTS
Hello thanks for using 2CarPros.
As a first step use scan tool read the fault codes to narrow the issue.
Run our guide for engine does not start.to start the engine we need spark,fuel and good compression.
Check if spark is present.
Check the fuel pump pressure.
check engine compression.
Please let us know what happens after the tests.
Mar 25, 2019 at 7:01 AM
