Car will crank but will not start
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
SMAKMAN35
I'm able to turn the fuel pump on and off. the car was hit on the left side and only curtain airbags were deployed. I had a mechanic run codes and he said the airbag module and airbags is keeping it from starting. this happened to me once before but I disconnected the battery and it seemed to work for months. This time it happened while driving and was able to put it in neutral and restart like 4 times before I pulled over. Would the airbags keep the car from starting? could it be something other like an O2 sensor? when the car does crank it also cranks a specific number of times.
Sep 28, 2019 at 5:29 AM
The short answer is yes. However, it depends on what codes are in the system. Some codes in the ABS will not prevent the start but if the crash impact sensors are the cause (which is likely because this is what tells the airbags to deploy then it will prevent a start.
As for cranking the specific number of times, that is by design. Basically the PCM determines the amount of times to crank the engine to try to start the vehicle. This is so that the starter does not get worn out and someone cannot just crank the engine excessively.
Unfortunately, we are going to have to dig into the codes and repair them before we can move onto other issues.
Sep 29, 2019 at 2:58 AM
