I bought the vehicle listed above at auction and when we try to start the car it will turn over and start very rough for about 5 or 10 seconds and shut off and then it will just turn over and not start again. When putting a scanner on it the fault codes came back as cam shaft position sensor and crankshaft sensor so we replaced the 2 top ones and the crankshaft but then realized there were 4 camshaft sensors we could only find 1 more sensor in town so we bought that one and changed one sensor on the bottom bank b I believe. Although the scanner only identified 2 camshaft sensors as being faulty. The car is still doing the same thing no change we did notice the car is leaking oil and the light on the dashboard is saying low oil pressure when it does start for a couple seconds. What do you think is the problem?
Mar 26, 2023 at 3:19 PM
