Car will not start
162,300 MILES • 4 CYL • FWD • AUTOMATIC
CHERYLCWOLFF
We put a new battery in on 11/25/16 had to jump start it twice. Tested the battery it came up good. It ran fine then went out next morning and it would not even make a clicking sound and jumper cables would not start it. What should I check first? Second? Alternator and charging system was tested the previous two times car would not start and tested normal.
Jan 1, 2017 at 9:40 PM
JOHNNY G.JR
  • 320 POSTS
Have battery cables checked for internal corrosion using a voltage drop test from positive battery cable post to positive starter post. Anything higher than .2 volts is normally unacceptable.
Jan 2, 2017 at 6:22 PM
DOCFIXIT
  • 18,828 POSTS
I agree and G.JR great call on voltage drop test most Techs never use or even no how.
Jan 3, 2017 at 3:29 AM
