Car will not start
120,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
ODDONE86
I replaced the fuel pump recently, and for some reason the car won’t start. The dash doesn’t light up either, not sure if the two are connected. I checked all the fuses and everything checks out to be okay.
Mar 17, 2019 at 8:14 PM
Good morning,
Can you hear the pump run when you turn the key on?
Did you check for spark?
These two need to be checked first.
Mar 17, 2019 at 9:46 PM
