Car will not start?
160,000 MILES
DSHERI1
  • 6 POSTS
When I push the start button the car tries to start but won’t turn over all the way.
Sep 6, 2024 at 11:05 PM
  • 55,849 POSTS
It sounds like you need a new battery, so the engine cranks over and then stops? Do you hear a ratcheting sound? We need more information to help you. Please upload a video in your response of any problems so we can see.
Here is how to remove the battery so you can have it tested:
This guide can help out as well:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Also, this video is for an engine that does not crank over:
https://youtu.be/6YRW8fyNudY?si=81kqTqh_MlfNyW02
Sep 7, 2024 at 1:08 AM
DSHERI1
  • 6 POSTS
When I got it towed they checked my battery and it was at a good level.
Sep 7, 2024 at 1:28 AM
  • 55,849 POSTS
Bummer, it sounds like the engine has no compression. Can you tell me what engine you have and how many miles are on it? To confirm the compression issue lets go over this guide:
and
https://www.2carpros.com/articles/the-reasons-for-low-compression
Thank for the video, it helps. Please go over these guides and get back to us.
Sep 7, 2024 at 3:25 AM
DSHERI1
  • 6 POSTS
It’s a V6 3.6L, miles 155,773.
Sep 7, 2024 at 3:32 AM
  • 55,849 POSTS
So, this engine has a timing chain which doesn't break very often. Any check engine light on or overheating while the engine was still running?
Sep 7, 2024 at 3:51 AM
DSHERI1
  • 6 POSTS
The check engine light is on but it hasn’t overheated.
Sep 7, 2024 at 7:50 AM
  • 55,849 POSTS
Okay, let's run the codes and check the compression, this guide will help you get the codes:
Please go over this guide and get back to us.
Sep 8, 2024 at 4:11 AM
DSHERI1
  • 6 POSTS
I’ve posted a picture of the codes.
Sep 9, 2024 at 4:13 AM
  • 55,849 POSTS
Okay, these cods are telling us the engine has over heated and that the thermostat needs to be replaced but this will not keep the engine from starting cold. I would head out to the auto parts store and rent a compression gauge for cheap or free and do the test.
Sep 9, 2024 at 5:30 AM
