Car will not start?
150,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
BENJI134
Car listed above is an ES. The solenoid clicks but the starter wont crank. The battery is fine, no starter relay as far as I know. Any ideas?
Sep 19, 2022 at 9:02 AM
BENJI134
It only started doing this after I went to a gas station, and it wouldn't start after that.
Sep 19, 2022 at 9:03 AM
SQM
  • 6,383 POSTS
If you are just getting clicks on the solenoid, that means that the solenoid is getting power, but the starter is not engaging. It does sound like a faulty starter.
It could also be due to corroding or loose connection to the starter.
So, checking the starter and battery cable should be the first step.
Here is a helpful guide:
Let me know of any questions.
Sep 19, 2022 at 2:14 PM
BENJI134
The starter is fine, and I also bought a new one and used that, but the same problem still happens. Also, I got a new battery and that didn't work. I also forgot to mention that for a while I was able to start it with a jump but then after like 5 to 7 times that wouldn't work anymore. we also tested the new battery and that should be fine too.
Sep 19, 2022 at 5:05 PM
BENJI134
Found the issue the upper terminal was replaced at some time ant the person doing it did do it correctly causing it to short when the key was turned, we figured it out by using a dmm to the voltage to the starter as we turned the key and it dropped 10 volts.
Sep 20, 2022 at 12:25 PM
SQM
  • 6,383 POSTS
Glad that you are able to find the issue and sharing it with us.
Sep 20, 2022 at 3:46 PM
