Car will not start
206,577 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
TIBELSHAW
My car out of nowhere won’t start. It’s just got under half a tank of petrol. All the dashboard lights turn on, radio and headlights too, but the car is still struggling to start.. Any guidance would be much appreciated.
Jun 13, 2019 at 3:47 PM
TIBELSHAW
The car cranks but won’t run. The engine light stays on but a can’t hear the hum from the fuel pump when i switch the ignition on either.
Jun 13, 2019 at 4:30 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Most times, it is either a fuel or ignition related issue. I need you to try something. See if starts for a couple seconds using starting fluid. If it does,. then it is a fuel related issue even though you hear the pump. If it doesn't, then it is ignition related.
Here are links that you may find helpful:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Here are the manufacturer's specs for fuel pressure:
Fuel line pressure .................... 375 - 450 kPa [3.9 - 4.5 kgf/sq.cm, 55 - 65 psi]
If it doesn't start with starting fluid, check for spark.
Jun 14, 2019 at 2:36 PM
TIBELSHAW
Thank you for your response. Will let you know if anything works or not.
Jun 16, 2019 at 9:02 AM
  • 110,248 POSTS
Welcome back:
That sounds like a plan. If you have questions as you are working on it, let me know.
Take care and I will watch for the results.
Jun 16, 2019 at 1:21 PM
