car wont start
160,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
GREENCHEVYMALIBU
  • 230 POSTS
I have a 98 neon coupe that had a 2.0 sohc. the timing belt broke. I had a crashed 2.0 dohc car so I swapped the motors. It started right up when I was done with the swap. I had it idling for around 20 minutes. As it was idling it just died like someone had turned the key to off. Now it wont start back up. It just cranks. I'm a bit lost since it was running fine for 20 minutes with no check engine light on. where should I start?
Feb 7, 2016 at 7:11 AM
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online.
Feb 7, 2016 at 7:18 AM
GREENCHEVYMALIBU
  • 230 POSTS
car doesn't have a security system.
Feb 7, 2016 at 7:42 AM
HMAC300
  • 48,601 POSTS
yes iti does it's for anti theft
Feb 7, 2016 at 8:34 AM
GREENCHEVYMALIBU
  • 230 POSTS
How do you reset it? I have a black key and no phobs.
Feb 7, 2016 at 9:32 AM
GREENCHEVYMALIBU
  • 230 POSTS
If it was the anti theft would it of ran for 20 minutes with no problems?
Feb 7, 2016 at 9:41 AM
HMAC300
  • 48,601 POSTS
try locking drivers door then unlocking to reset if that doesn't work look online for 98 dodge neon secrity reset...i have no further comments on this
Feb 7, 2016 at 10:49 PM
GREENCHEVYMALIBU
  • 230 POSTS
This neon doesn't have a anti lock security system. it was the pigtail on the camshaft position sensor. The wires were bare and touch each other. Replaced pigtail.
Feb 10, 2016 at 2:10 PM
  • 55,746 POSTS
Great to hear you fixed the problem, this information will help others
Mar 7, 2016 at 2:26 AM
